Einleitung
This removal guide shows the proper steps to replace the DC Power Jack in the Amazon Echo Show 5. This significant piece allows there to be power throughout the device.
Was du brauchst
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Carefully open the device by folding it open along the top edge where the camera is located.
Remove the three ZIF connector ribbon cables that connect the speaker housing to the display housing.
Use tweezers to peel off the metallic tape from the I/O board.
