Einleitung
In order to have success when attempting to replace the speaker, be sure to remain patient and use caution when disconnecting various parts of this device.
Was du brauchst
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Carefully open the device by folding it open along the top edge where the camera is located.
Remove the three ZIF connector ribbon cables that connect the speaker housing to the display housing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Ive taken my speaker out and tested it, its fine
Its a software or dac chip issue.
Agreed , my speaker is muffled , ive just disassembled and want to test the speaker .
And... Yes ive reset thr device etc many times.
