Einleitung
If you give the amazon echo studio some voice commands, and it does not respond to them, and/or if you noticed the lightboard does not light up anymore, this guide will help you replace the lightboard.
Was du brauchst
Flip the device upside down.
Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
Now unscrew the the single 10 mm Phillips screw.
Remove the power supply board.
Remove the two screws located across from each other on the outside of the plastic ring shown.
Remove the plastic outer ring that hugs the inside of the edges of the device.
Remove the two 2.7 mm screws with a T10 Torx screwdriver.
Once the screws are removed, take the power supply's baseplate out of the unit.
On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
After removing the six screws from the inside, lift the top speaker cover.
After the screws are removed, carefully lift the lightboard and disconnect the ribbon.
Eine weitere Person hat diese Anleitung absolviert.
