Zum Hauptinhalt wechseln
Amazon Fire HD 10 Front Facing Camera Replacement
Was du brauchst
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: Schritt 1, Bild 1 von 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: Schritt 1, Bild 2 von 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: Schritt 1, Bild 3 von 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 3, Bild 1 von 2 Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 1 von 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 2 von 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 3 von 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  6. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 6, Bild 1 von 2 Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  7. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 7, Bild 1 von 2 Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 7, Bild 2 von 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  8. Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 8, Bild 1 von 2 Amazon Fire HD 10 Front Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jaie Hillery
1.718 Reputation
10 Anleitungen geschrieben
USF Tampa, Team 16-6, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Mitglieder
22 Anleitungen geschrieben
Ein Kommentar
Can this camera module be upgraded with a better version?
Jimmy Kee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,117
