Einleitung
You will need to use the screen replacement guide as a prerequisite.
Was du brauchst
Use a plastic opening tool to pry the screen up in the right hand corner.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Lift the black plastic cover once the screws are removed.
Place aside for later reassembly.
Eine weitere Person hat diese Anleitung absolviert.
