Einleitung
Use this guide to replace the motherboard in your Amazon Fire HD 10.
Was du brauchst
Use a plastic opening tool to pry the screen up in the right hand corner.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
After the battery is totally free of any adhesion, simply lift the battery from the case.
Gently grab the camera and pull to remove.
The camera is now free from the motherboard.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Lift the black plastic cover once the screws are removed.
Place aside for later reassembly.
Lift and pull the motherboard down, gently, towards the case using the tweezers.
14 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
Just for the record, my screws were T4, not T5.
what you left out is the speakers are they still attached to the motherboard you get 15 points
Is this the Kindle? Not the Tablet?
