Einleitung
You will need to use the screen replacement guide as a prerequisite.
Was du brauchst
Use a plastic opening tool to pry the screen up in the right hand corner.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Gently grab the camera and pull to remove.
The camera is now free from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
