Zum Hauptinhalt wechseln
Amazon Fire HD 10 Screen Replacement
Was du brauchst
  1. Amazon Fire HD 10 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Amazon Fire HD 10 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Amazon Fire HD 10 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: Schritt 2, Bild 1 von 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: Schritt 3, Bild 1 von 2 Amazon Fire HD 10 Screen Replacement: Schritt 3, Bild 2 von 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the screen and digitizer from the case completely.
Abschluss
27 weitere Personen haben diese Anleitung absolviert.
Jaie Hillery
1.718 Reputation
10 Anleitungen geschrieben
USF Tampa, Team 16-6, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Mitglieder
22 Anleitungen geschrieben
16 Kommentare
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Antwort
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Antwort
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Antwort
What is needed to attach the screen back to the case?
Jimmy Lee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 44
Letzte 30 Tage: 287
Insgesamt: 35,711
