Zum Hauptinhalt wechseln
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
Was du brauchst
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: Schritt 1, Bild 1 von 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: Schritt 1, Bild 2 von 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: Schritt 1, Bild 3 von 3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: Schritt 2, Bild 1 von 1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: Schritt 3, Bild 1 von 1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: Schritt 4, Bild 1 von 2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Abschluss
Omir Rosado
725 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-4, Passmore Fall 2016 Mitglied von USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 555
