Zum Hauptinhalt wechseln
Amazon Fire HD 8 12th Gen Speakers Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: Schritt 1, Bild 1 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: Schritt 1, Bild 2 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: Schritt 1, Bild 3 von 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 2, Bild 1 von 2 Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 2, Bild 2 von 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Speakers Replacement, Speakers: Schritt 3, Bild 1 von 1
    • Disconnect the red and black wires connected to the motherboard.
  4. Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 4, Bild 1 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 4, Bild 2 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 4, Bild 3 von 3
    • Heat glue up to loosen the black and red wires, then lift and remove black and red wires.
    • Be careful of hot metals/parts and hot tools.
  5. Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 5, Bild 1 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 5, Bild 2 von 3 Amazon Fire HD 8 12th Gen Speakers Replacement: Schritt 5, Bild 3 von 3
    • Get metal speaker parts hot as well and lift the metal speaker up.
    • Do this for the other set of speakers and repeat the steps again.
    • Be careful of hot tools and hot parts.
Abschluss
Jaden Palmer
485 Reputation
4 Anleitungen geschrieben
University of Memphis, Team 1-1, Sneed Fall 2023 Mitglied von University of Memphis, Team 1-1, Sneed Fall 2023
UM-SNEED-F23S1G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 93
