Einleitung
In this guide, we will show you how to replace the rear-facing camera. Before you start, make sure your device is powered off.
Was du brauchst
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
Flip up the tab on the ZIF connector at the end of the ribbon cable.
Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
2 weitere Personen haben diese Anleitung absolviert.
