Einleitung
In this guide, we will show you how to open the device and replace the screen. Before you start, make sure your device is powered off.
Was du brauchst
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
27 weitere Nutzer:innen haben diese Anleitung absolviert.
18 Kommentare
Thankyou so much!
Very nice, but even Amazon is not marketing the replacement screens.
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Fingers crossed Amazon offers more parts in the future! :)
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
