Zum Hauptinhalt wechseln
Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement
Was du brauchst
  1. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Screen: Schritt 1, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Screen: Schritt 1, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Screen: Schritt 1, Bild 3 von 3
    • Ensure that the device is turned off.
    • Holding the device firmly, wedge a plastic opening tool between the speaker cover and the device. Then pry up to separate it from the device.
    • Then begin to firmly pry up the plastic cover with the plastic opening tool.
    • The backing is connected with adhesive so force may be necessary.
    • Be careful to not damage the plastic in any way.
    • Once you can fit your finger under the plastic cover, begin to slide your finger down the cover while simultaneously prying up.
  2. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 2, Bild 1 von 2 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 2, Bild 2 von 2
    • Once you reach the end of the plastic cover you should be able to completely remove it from the device.
  3. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 3, Bild 1 von 2 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 3, Bild 2 von 2
    • Use a T5 screwdriver to remove the four 3.5 mm T5 screws at the top of the device, where the black plastic trim was located.
  4. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 4, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 4, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 4, Bild 3 von 3
    • Release the two clear plastic clips at the top of the device near the speaker using the spudger.
    • Simply push down the clip with the tip of the spudger.
    • Push lightly to ensure that the clips aren't damaged.
  5. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 5, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 5, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4.
    • Pry the screen very gently to avoid cracking the glass
    • Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
    • The Amazon Fire can now be opened with the two flex cables at the base still connected
  6. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 6, Bild 1 von 2 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 6, Bild 2 von 2
    • Now we have to remove the two flex cables attached to both the screen assembly and body of the device.
    • The cable addressed in step 8 is highlighted in orange.
  7. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 7, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 7, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 7, Bild 3 von 3
    • First turn the device 90 degrees counterclockwise.
    • Wedge a spudger or plastic opening tool under the black flap of the larger connector and lift up.
    • Pull the belt out of the connector and lift it up.
  8. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 8, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 8, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 8, Bild 3 von 3
    • Turn the device 180 degrees.
    • Repeat step 7 for the smaller flex cable connection.
  9. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement: Schritt 9, Bild 1 von 1
    • Your screen assembly has now been removed and can be replaced.
  10. Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Speaker: Schritt 10, Bild 1 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Speaker: Schritt 10, Bild 2 von 3 Amazon Fire HDX 8.9" 4th Gen. Speaker Replacement, Speaker: Schritt 10, Bild 3 von 3
    • Using a T5 screwdriver remove the two 3 mm T5 screws for the speaker you are replacing, or if you need to replace both speakers remove all four screws.
    • The speakers have now been removed and can be replaced.
Abschluss
Jacob Rogers
285 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-8, Maness Spring 2016 Mitglied von Cal Poly, Team 1-8, Maness Spring 2016
CPSU-MANESS-S16S1G8
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 364
