Einleitung
These steps will guide you through the disassembly and the replacement of the Fire TV Cube motherboard. This guide requires the metal flathead spudger. Use extra caution when detaching wires.
Ersatzteile
Keine Ersatzteile angegeben.
Using a metal spudger, push down between the edge seals on the base and pry off the base.
Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
Lift the black latch by gently prying up with the flat end of the Spudger.
Detach the copper tap by pulling it out.
Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
3 weitere Nutzer haben diese Anleitung absolviert.
