Zum Hauptinhalt wechseln
Amazon Fire TV Cube Motherboard Replacement
Was du brauchst
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: Schritt 1, Bild 1 von 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: Schritt 1, Bild 2 von 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: Schritt 2, Bild 1 von 3 Amazon Fire TV Cube Motherboard Replacement: Schritt 2, Bild 2 von 3 Amazon Fire TV Cube Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: Schritt 4, Bild 1 von 2 Amazon Fire TV Cube Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: Schritt 6, Bild 1 von 2 Amazon Fire TV Cube Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: Schritt 7, Bild 1 von 2 Amazon Fire TV Cube Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Gently pry the motherboard up and off.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
where do you buy the mother board ?
Sam Handa - Antwort
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 1,661
