Zum Hauptinhalt wechseln
Amazon Fire TV Stick Remote Battery Replacement
Was du brauchst
  1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: Schritt 1, Bild 1 von 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: Schritt 1, Bild 2 von 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
  2. Amazon Fire TV Stick Remote Battery Replacement: Schritt 2, Bild 1 von 1
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew Busse
870 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-3, Harley SU 2016 Mitglied von IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Mitglieder
13 Anleitungen geschrieben
35 Kommentare
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Antwort
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber -
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Antwort
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Kelsea Weber -
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 80
Letzte 30 Tage: 346
Insgesamt: 115,861
