Zum Hauptinhalt wechseln
Amazon Kindle DX SIM Card Replacement
Was du brauchst
  1. Amazon Kindle DX SIM Card Replacement, Sim Card: Schritt 1, Bild 1 von 1
    • Use the plastic opening tool to push against the top part of the e-reader to open the device.
  2. Amazon Kindle DX SIM Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the plastic top.
  3. Amazon Kindle DX SIM Card Replacement: Schritt 3, Bild 1 von 2 Amazon Kindle DX SIM Card Replacement: Schritt 3, Bild 2 von 2
    • Locate the two small screws on each corner.
    • Remove the two 40mm screws with a Phillips #0 screwdriver.
  4. Amazon Kindle DX SIM Card Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to take the off the metal plate.
  5. Amazon Kindle DX SIM Card Replacement: Schritt 5, Bild 1 von 1
    • Locate and remove the SIM card slot.
  6. Amazon Kindle DX SIM Card Replacement: Schritt 6, Bild 1 von 1
    • Use the spudger to push the metal lid backwards, as pictured.
  7. Amazon Kindle DX SIM Card Replacement: Schritt 7, Bild 1 von 1
    • Open the lid to replace the SIM card.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 1-5, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Need to do this with a kindle I have is does it need to be replaced with a 3G sim
Melanie Tague - Antwort
I have 10 kindle Docs, first or second generation. I am too old to use the new kindles, fire, paperwhites. Can I make my old kindles work? I have them for different genres, 3200 books total. Please before I’m too old to care. Thank you for your time. I’m desperate.
Lilli Bean
Lillibean - Antwort
DXs. Spellcheck messed up. Not me!
Lillibean - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 60
Insgesamt: 3,615
