Einleitung
This guide offers step-by-step instructions on how to replace a battery on a Kindle Fire 7.
Was du brauchst
Insert the opening tool into the Kindle side.
Work around the sides of the device to free all clips.
Remove the two screws securing the battery connector cover using the Phillips #00 screwdriver.
Remove the battery connector cover.
Disconnect the battery
Fit the tip of the plastic opening tool under the bottom right of the battery.
Remove the battery from the frame
2 weitere Nutzer:innen haben diese Anleitung absolviert.
