Einleitung
The drive motor is what powers the shredding teeth via the drive gears. The motor may burn out due to age or extended use. It is found attached to the main shredder housing holding the shredding teeth and the drive gears.
Was du brauchst
Remove the six 14mm PH1 screws holding the bottom cover in place.
Remove the cover by lifting straight upwards.
Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
