Einleitung
Sometimes the AUX Input Jack will stop working properly and may need replacing. This guide requires use of a Soldering Iron and should only be attempted by those with soldering experience. If soldered incorrectly, your device may be permanently damaged.
Was du brauchst
Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
Tilt the case downwards until the speakers fall out of their housings.
Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
Gently pull each plastic connector from the motherboard.
Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
Lift the motherboard off the face plate, exposing the battery.
Lift the battery out of its housing.
Use your fingers to pull casing off by the ribbon.
Use a Phillips #1 screwdriver to remove the two 7.6mm screws that hold the board in place.
Use plastic opening tool to lift up the board.
Use plastic opening tool to gently push the aux input jack out of its housing.
Use the soldering iron to heat up solder joint and desoldering wick to remove the solder on each solder pad.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
