Zum Hauptinhalt wechseln
AmazonBasics BTV1 Battery Replacement
Was du brauchst
  1. AmazonBasics BTV1 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 AmazonBasics BTV1 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Battery Replacement: Schritt 2, Bild 1 von 2 AmazonBasics BTV1 Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Battery Replacement: Schritt 3, Bild 1 von 2 AmazonBasics BTV1 Battery Replacement: Schritt 3, Bild 2 von 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Battery Replacement: Schritt 4, Bild 1 von 2 AmazonBasics BTV1 Battery Replacement: Schritt 4, Bild 2 von 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Battery Replacement: Schritt 5, Bild 1 von 2 AmazonBasics BTV1 Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Shannon
1.039 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 14-2, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Mitglieder
8 Kommentare
donde consigo la bateria?
bnet_d72 - Antwort
Nice job, Chris! Thank you.
David Printz - Antwort
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Antwort
Need information on where to get a replacement battery!
dan - Antwort
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 25
Insgesamt: 3,034
