Zum Hauptinhalt wechseln
Ambient Weather WS-1001-Wifi Battery Replacement
Was du brauchst
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: Schritt 2, Bild 1 von 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: Schritt 3, Bild 1 von 2 Ambient Weather WS-1001-Wifi Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: Schritt 4, Bild 1 von 1
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S1-G2, Harley Fall 2017 Mitglied von IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 748
