Zum Hauptinhalt wechseln
Ambient Weather WS-1001-Wifi LCD Screen Replacement
Was du brauchst
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: Schritt 4, Bild 1 von 2 Ambient Weather WS-1001-Wifi LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Abschluss
IUPUI, Team S1-G2, Harley Fall 2017 Mitglied von IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Mitglieder
3 Anleitungen geschrieben
2 Kommentare
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Antwort
Exactly right.
j drag -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 367
