Zum Hauptinhalt wechseln
Ambient Weather WS-1001-Wifi Push Button Replacement
Was du brauchst
  1. Ambient Weather WS-1001-Wifi Push Button Replacement, Push Button: Schritt 1, Bild 1 von 2 Ambient Weather WS-1001-Wifi Push Button Replacement, Push Button: Schritt 1, Bild 2 von 2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a small plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Push Button Replacement: Schritt 2, Bild 1 von 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Push Button Replacement: Schritt 3, Bild 1 von 1
    • Heat up solder with soldering iron, and quickly use a desoldering gun to remove solder on the pins.
  4. Ambient Weather WS-1001-Wifi Push Button Replacement: Schritt 4, Bild 1 von 1
    • Once the button is removed place the new button down on the board.
    • Apply solder with soldering iron to the pins.
Abschluss
Trevor Hansen
104 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G2, Harley Fall 2017 Mitglied von IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 224
