Zum Hauptinhalt wechseln
American Plumber Water Filter WC34-PR Replacement
Was du brauchst
  1. American Plumber Water Filter WC34-PR Replacement, Filter: Schritt 1, Bild 1 von 1
    • Locate the water filter in your home.
    • The water filter is typically by where the water comes into the house.
  2. American Plumber Water Filter WC34-PR Replacement: Schritt 2, Bild 1 von 2 American Plumber Water Filter WC34-PR Replacement: Schritt 2, Bild 2 von 2
    • Rotate the lever near the water filter up to turn off the water to the house.
    • This may differ depending on your setup.
  3. American Plumber Water Filter WC34-PR Replacement: Schritt 3, Bild 1 von 2 American Plumber Water Filter WC34-PR Replacement: Schritt 3, Bild 2 von 2
    • Turn on a faucet inside the house to drain the water out of the pipes.
    • Leave the faucet on until no more water comes out.
  4. American Plumber Water Filter WC34-PR Replacement: Schritt 4, Bild 1 von 1
    • Place a bucket under the filter.
  5. American Plumber Water Filter WC34-PR Replacement: Schritt 5, Bild 1 von 2 American Plumber Water Filter WC34-PR Replacement: Schritt 5, Bild 2 von 2
    • Press the button on top of the device for approximately 10-15 seconds until all of the water is drained.
  6. American Plumber Water Filter WC34-PR Replacement: Schritt 6, Bild 1 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 6, Bild 2 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 6, Bild 3 von 3
    • Hold the top of the device and the pipes steady and rotate the clear part of the filter to the left to remove it.
    • Using excessive force may damage your pipes.
    • If the filter housing is stuck, use a strap wrench to loosen the filter.
    • Loop the strap around the filter and place the remaining strap into the slot in the wrench.
    • Ensure the handle of the wrench is close to the filter container and that there is no slack in the strap.
    • Grip the handle firmly to hold the strap in place.
    • Twist to the left to unscrew the filter housing.
  7. American Plumber Water Filter WC34-PR Replacement: Schritt 7, Bild 1 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 7, Bild 2 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 7, Bild 3 von 3
    • Remove the filter from the plastic housing.
    • Pour out the remaining water into the bucket.
  8. American Plumber Water Filter WC34-PR Replacement: Schritt 8, Bild 1 von 2 American Plumber Water Filter WC34-PR Replacement: Schritt 8, Bild 2 von 2
    • Use a paper towel to wipe sediment out of the filter housing and the gasket.
  9. American Plumber Water Filter WC34-PR Replacement: Schritt 9, Bild 1 von 1
    • Inspect the gasket to see if it has visible damage or dirt.
    • If the gasket is dirty of damaged, the device may leak when reassembled.
    • Clean any dirt off the rubber ring.
    • If the rubber ring is damaged, replace it with a new gasket.
  10. American Plumber Water Filter WC34-PR Replacement: Schritt 10, Bild 1 von 1
    • Place a new filter into the housing.
  11. American Plumber Water Filter WC34-PR Replacement: Schritt 11, Bild 1 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 11, Bild 2 von 3 American Plumber Water Filter WC34-PR Replacement: Schritt 11, Bild 3 von 3
    • Screw the filter housing back on.
    • The filter must be straight and centered in the housing.
  12. American Plumber Water Filter WC34-PR Replacement: Schritt 12, Bild 1 von 2 American Plumber Water Filter WC34-PR Replacement: Schritt 12, Bild 2 von 2
    • Turn the water to the house back on.
    • Once unit is filled with water, inspect the filter to ensure there is no leakage.
Ziellinie
BobTheBuilder
205 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 33
Letzte 30 Tage: 163
Insgesamt: 1,980
