Zum Hauptinhalt wechseln
Einleitung
Use this guide to remove or replace a driver pad on a Clarke Floor Sander 07163A 2017.
This guide shows the removal of just one pad, but the procedure for the other two pads is identical.
Werkzeuge
Ersatzteile
  1. Before you begin, be sure that the sander is unplugged and powered off.
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. Peel the hook-and-loop sandpaper disc off of the driver assembly.
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad. Remove the driver pad from the sanding disc.
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Adam O'Camb
145.870 Reputation
417 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
138 Mitglieder
17.020 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 9
Letzten 30 Tage: 59
Insgesamt: 1,459
