Einleitung
In this guide we will replace the two triple-A batteries located in the back panel of the scale. This guide should be used when the scale runs out of power.
Was du brauchst
Use your finger to pull up on the battery cover tab and lift to remove.
Congratulations! You have successfully replaced the batteries of your American Weigh AWS -100!
2 weitere Personen haben diese Anleitung absolviert.
