Zum Hauptinhalt wechseln
Analogue Pocket Battery Cell Replacement
Was du brauchst
  1. Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: Schritt 1, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: Schritt 1, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: Schritt 1, Bild 3 von 3
    • Allow your Analogue Pocket's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Battery Cell Replacement, Unfasten the battery shell: Schritt 2, Bild 1 von 2 Analogue Pocket Battery Cell Replacement, Unfasten the battery shell: Schritt 2, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Battery Cell Replacement, Remove the battery shell: Schritt 3, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery shell: Schritt 3, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery shell: Schritt 3, Bild 3 von 3
  4. Analogue Pocket Battery Cell Replacement, Disconnect the battery: Schritt 4, Bild 1 von 2 Analogue Pocket Battery Cell Replacement, Disconnect the battery: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 5, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 5, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 5, Bild 3 von 3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Battery Cell Replacement, Heat the battery housing: Schritt 6, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Heat the battery housing: Schritt 6, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Heat the battery housing: Schritt 6, Bild 3 von 3
    • Strong adhesive secures the battery cell to its housing.
    • Heat an iOpener and apply it to the top of the plastic battery housing for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer to lightly heat the housing. But be careful, as the plastic can easily be warped.
  7. Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: Schritt 7, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: Schritt 7, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: Schritt 7, Bild 3 von 3
    Plastic Cards
    $2.99
    • Take care not to bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Firmly secure the battery with one hand.
    • With your free hand, insert a plastic card between one of the long edges of the battery cell and its housing.
    • Pry up with the plastic card and apply steady pressure until a gap forms.
    • Be patient and allow plenty of time for the adhesive to separate. If you're having trouble creating a gap, apply more heat and try again.
    • Slide the card under the battery cell.
  8. Analogue Pocket Battery Cell Replacement: Schritt 8, Bild 1 von 2 Analogue Pocket Battery Cell Replacement: Schritt 8, Bild 2 von 2
    • Slide the plastic card back and forth under the battery cell to separate the adhesive.
  9. Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 9, Bild 1 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 9, Bild 2 von 3 Analogue Pocket Battery Cell Replacement, Remove the battery: Schritt 9, Bild 3 von 3
    Tesa 61395 Tape
    $8.95
    • Use the plastic card to lift the battery cell out of its housing and remove it.
    • During reassembly:
    • When installing a battery cell, make sure its cable goes into its cutout in the housing.
    • If your new battery cell comes with pre-installed adhesive, remove the plastic backing and firmly press the cell into place in its housing.
    • If your new battery cell doesn't have adhesive, use strips of double-sided tape such as Tesa Tape to secure it in the housing.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
178.350 Reputation
1.142 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
25.206 Anleitungen geschrieben
3 Kommentare zur Anleitung
Where do I get the battery?
Ale Gan - Antwort Teilen
I too would like to know the specs of the battery. Thank you.
PM1 Chicago - Antwort Teilen
Here you go!
Model: 901-864974-011
Nominal Voltage: 3.7V
Rated Capacity: 4300mAh 15.91Wh
Spencer Day - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 123
Insgesamt: 3,897
