Zum Hauptinhalt wechseln
Andobil Easy Clip Car Mount Replacement
Was du brauchst
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: Schritt 1, Bild 1 von 1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: Schritt 2, Bild 1 von 1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: Schritt 3, Bild 1 von 2 Andobil Easy Clip Car Mount Replacement: Schritt 3, Bild 2 von 2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: Schritt 4, Bild 1 von 1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: Schritt 5, Bild 1 von 2 Andobil Easy Clip Car Mount Replacement: Schritt 5, Bild 2 von 2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: Schritt 6, Bild 1 von 1
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: Schritt 7, Bild 1 von 1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: Schritt 8, Bild 1 von 1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: Schritt 9, Bild 1 von 1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: Schritt 10, Bild 1 von 1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alexander Tavares
205 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S2-G16, Riel Spring 2021 Mitglied von UMass Dartmouth, Team S2-G16, Riel Spring 2021
UMASSD-RIEL-S21S2G16
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 82
Insgesamt: 1,729
