Zum Hauptinhalt wechseln
Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Battery Replacement: Schritt 2, Bild 1 von 1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
  3. Andoer HDV 107 Battery Replacement: Schritt 3, Bild 1 von 1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
Abschluss
Isaac Saron
516 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G4, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G4, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 340
