Einleitung
This guide provides essential information and steps on how to replace a faulty camera, including a step by step disassembling and removing instructions. Follow steps 1-3 to open the device. Ignore steps 4 and 5 and go straight to step 6 after doing so.
Was du brauchst
Remove the two 00 Phillips screws located in the right hand side of the tablet.
Start by removing the electrical tape covering the camera, located at the top left corner of the device.
Lift up the black plastic lock on the ZIF connector with tweezers.
Gently remove the camera by removing the power cord with tweezers. The camera should release easily: do not twist or pull too hard.
Replace the camera with a new one.
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
Eine weitere Person hat diese Anleitung absolviert.
