Zum Hauptinhalt wechseln
Android tablet Nobis NB09 Screen Replacement
Was du brauchst
  1. Android tablet Nobis NB09 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Android tablet Nobis NB09 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Android tablet Nobis NB09 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: Schritt 2, Bild 1 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 2, Bild 2 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 2, Bild 3 von 3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: Schritt 3, Bild 1 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 3, Bild 2 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 3, Bild 3 von 3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: Schritt 4, Bild 1 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 4, Bild 2 von 3 Android tablet Nobis NB09 Screen Replacement: Schritt 4, Bild 3 von 3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Enea Osmann
158 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Mitglied von UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
The digitizer replacement instructions was great. Thanks
steven warren - Antwort
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 1,497
