Zum Hauptinhalt wechseln
Angelcare AC401 Baby Monitor Disassembly
Was du brauchst
  1. Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: Schritt 1, Bild 1 von 2 Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: Schritt 1, Bild 2 von 2
    • first remove the 2 screws at the green plastic plate.
  2. Angelcare AC401 Baby Monitor Disassembly: Schritt 2, Bild 1 von 1
    • remove the plastic plate ( battery compartment)
    • you'll see that there are 2 more screws. Remove them.
  3. Angelcare AC401 Baby Monitor Disassembly: Schritt 3, Bild 1 von 2 Angelcare AC401 Baby Monitor Disassembly: Schritt 3, Bild 2 von 2
    • now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
  4. Angelcare AC401 Baby Monitor Disassembly: Schritt 4, Bild 1 von 2 Angelcare AC401 Baby Monitor Disassembly: Schritt 4, Bild 2 von 2
    • now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
    • be carefull for the electric wires.
  5. Angelcare AC401 Baby Monitor Disassembly: Schritt 5, Bild 1 von 2 Angelcare AC401 Baby Monitor Disassembly: Schritt 5, Bild 2 von 2
    • 2 battery's were exploded so the acid was on the black electric power wire.
    • use a cotton swab with a little bit of destilled water.
  6. Angelcare AC401 Baby Monitor Disassembly: Schritt 6, Bild 1 von 1
    • remove the 2 PCB's by removing the screws shown in the picture.
  7. Angelcare AC401 Baby Monitor Disassembly: Schritt 7, Bild 1 von 1
    • pull the first PCB up and remove the screws of the second PCB.
    • after removing the two PCB's, clean the acid on the PCB.
    • after cleaning the PCB's put it al together again.
    • first remove the battery lid. 1 screw.
    • slide it out like you see in picture
    • remove battery's
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin D
7.294 Reputation
21 Anleitungen geschrieben
13 Kommentare
Thanks for this. I couldn't figure out how to get the blue clip off without breaking it to clean some dirt on the screen. Googled it, found this, job done.
Pete H - Antwort
Sometimes the activity of the reference quartz is 11,150 MHz, and the devices do not find each other.
I have so repaired the parent module.
Dmitriy, the city of Volzhsky.
Dmitriy N - Antwort
Hi Dimitriy - I am experiencing the issue with not finding devices each other. How have you fix it ? Is it a matter of replacing the reference quartz with new one ?
Jan - Antwort
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Terese Rehn - Antwort
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 14,851
