Zum Hauptinhalt wechseln
Anker 2.4G Wireless Mouse LED Replacement
Was du brauchst
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: Schritt 1, Bild 1 von 1
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: Schritt 3, Bild 1 von 2 Anker 2.4G Wireless Mouse LED Replacement: Schritt 3, Bild 2 von 2
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: Schritt 4, Bild 1 von 1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: Schritt 5, Bild 1 von 2 Anker 2.4G Wireless Mouse LED Replacement: Schritt 5, Bild 2 von 2
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: Schritt 7, Bild 1 von 1
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
Abschluss
Colin
406 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-39, Maness Winter 2014 Mitglied von Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 2,876
