Zum Hauptinhalt wechseln
Anker Soundcore 3 Battery Replacement
Was du brauchst
  1. Anker Soundcore 3 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Anker Soundcore 3 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
    • Insert a metal spudger in between the speaker's front grill and chassis.
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Battery Replacement: Schritt 2, Bild 1 von 3 Anker Soundcore 3 Battery Replacement: Schritt 2, Bild 2 von 3 Anker Soundcore 3 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
  3. Anker Soundcore 3 Battery Replacement: Schritt 3, Bild 1 von 2 Anker Soundcore 3 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 10 mm screws that secure the battery with a Phillips #00 screwdriver.
    • Firmly grasp the connector cable and gently pull up to remove it from the mainboard.
    • Remove the battery.
Abschluss
Deion V
303 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 58
Insgesamt: 220
