Zum Hauptinhalt wechseln
Anker Soundcore 3 Speaker Replacement
Was du brauchst
  1. Anker Soundcore 3 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Anker Soundcore 3 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Insert the metal spudger in between the speaker's front panel and casing
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Speaker Replacement: Schritt 2, Bild 1 von 3 Anker Soundcore 3 Speaker Replacement: Schritt 2, Bild 2 von 3 Anker Soundcore 3 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
Abschluss
Deion V
303 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 87
