Einleitung
The battery of the Anker Soundcore Flare Mini speaker is what holds a charge and creates power for the device. Without the battery, the speaker would not be able to function which makes it an essential component.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
Was du brauchst
Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
Remove six 10 mm screws holding the plastic cover in place using a Phillips #000 screwdriver.
Use your hand to pull the plastic cover off the bottom of the speaker.
Remove the single 10 mm screw holding the motherboard in place using a Phillips #000 screwdriver.
Lift the motherboard up.
Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
Remove the motherboard from the speaker.
Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
Remove the white plastic cover from the speaker.
Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
Use a spudger to loosen the cover from the inner components of the speaker.
Slide the cover completely off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
where can I buy the battery replacement component ?
Amazon, search for “rechargeable lithium ion battery 18650” it has to be a 2600 mAh 3.7v. I didn’t find one with the same connector so I just soldered the old one to the new battery, it works fine.
