Einleitung
In order to replace any component of the Anker Soundcore Flare Mini speaker, the rubber and plastic cover on the bottom of the speaker needs to be removed.
These parts protect the internal and electrical components of the speaker from the elements such as water and dirt. It also prevents internal damage or the loss of loose parts.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
Was du brauchst
Remove six 10 mm screws holding the plastic cover in place using a Phillips #000 screwdriver.
Use your hand to pull the plastic cover off the bottom of the speaker.
