Zum Hauptinhalt wechseln
Anker Soundcore Motion Boom A3118 Battery Replacement
Was du brauchst
  1. Anker Soundcore Motion Boom A3118 Battery Replacement, Motherboard: Schritt 1, Bild 1 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement, Motherboard: Schritt 1, Bild 2 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Use the metal spudger to remove the left and right shells surrounding the subwoofer.
    • Use the metal spudger to remove the front speaker grille.
  2. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 2, Bild 1 von 2 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove eight 15 mm screws located in the four corners of each front speaker using a Phillips #1 screwdriver.
  3. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use your hands to tear off the padding on the bottom of the speaker.
  4. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 4, Bild 1 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 4, Bild 2 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove all eight internal 15 mm screws from around the front speakers using a Phillips #1 screwdriver.
  5. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 5, Bild 1 von 2 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 5, Bild 2 von 2
    • Tear off the padding on the top of the speaker with your hands.
    • Remove the three 15 mm screws located on the top of the speaker using a Phillips #1 screwdriver.
  6. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 6, Bild 1 von 1
    • Pry the two large shells of the speaker apart with the metal spudger.
  7. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the speaker's white power cord from the motherboard.
    • Disconnect the rest of the cords connected to the motherboard.
  8. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 8, Bild 1 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 8, Bild 2 von 3 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 8, Bild 3 von 3
    • Remove the three 15 mm screws using a Phillips #1 screwdriver from the bottom left and right sides of the motherboard.
    • Remove the entire motherboard from the speaker.
  9. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 9, Bild 1 von 2 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the black wire from the motherboard.
  10. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the battery wire from the motherboard.
  11. Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 11, Bild 1 von 2 Anker Soundcore Motion Boom A3118 Battery Replacement: Schritt 11, Bild 2 von 2
    • Remove the five 10 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Separate the battery from the motherboard.
  12. Anker Soundcore Motion Boom A3118 Battery Replacement, Battery: Schritt 12, Bild 1 von 2 Anker Soundcore Motion Boom A3118 Battery Replacement, Battery: Schritt 12, Bild 2 von 2
    • Tear off the sticky padding from the battery.
    • The battery is now free and able to be replaced.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Michael
374 Reputation
2 Anleitungen geschrieben
Utah Tech University, Team 1-2, Crenshaw Fall 2024 Mitglied von Utah Tech University, Team 1-2, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G2
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 32
Insgesamt: 209
