Einleitung
Is your Anker Soundcore Space Q45 battery not holding a charge like it used to, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few simple steps. This guide will require you to remove the outer casing of the left headphone to access the battery.
Was du brauchst
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
Remove the inner plastic covering using an iFixit opening tool.
Pull directly up on the battery to release it from the tape holding it in place.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Hi. The microphone quality of Anker Q45 is terrible. Do you think it is possible to replace de microphone for a better one?
