Einleitung
Is your Anker Soundcore Space Q45 plastic covering damaged, preventing you from using the device to its full capability? If so, here is a guide to fix the problem.
Was du brauchst
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
Remove the inner plastic covering using an iFixit opening tool.
Eine weitere Person hat diese Anleitung absolviert.
