Einleitung
Is your Anker Soundcore Space Q45 power button stuck or not working, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few easy steps.
Was du brauchst
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
Remove the inner plastic covering using an iFixit opening tool.
Remove two screws from the motherboard with a Phillips screwdriver.
Remove the motherboard from the headphones.
Use a soldering iron to desolder the contacts connected to the three buttons on the bottom left-hand side of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
