Zum Hauptinhalt wechseln
Anki Vector Belts Replacement
  1. Anki Vector Belts Replacement, Belts: Schritt 1, Bild 1 von 1
    • Raise Vector's arms above his head.
  2. Anki Vector Belts Replacement: Schritt 2, Bild 1 von 2 Anki Vector Belts Replacement: Schritt 2, Bild 2 von 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Shay Takei
1.570 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G6, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 1,197
