Zum Hauptinhalt wechseln
Anki Vector Infrared Sensor Replacement
Was du brauchst
  1. Anki Vector Infrared Sensor Replacement, Belts: Schritt 1, Bild 1 von 1
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: Schritt 2, Bild 1 von 2 Anki Vector Infrared Sensor Replacement: Schritt 2, Bild 2 von 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: Schritt 3, Bild 1 von 2 Anki Vector Infrared Sensor Replacement, Infrared Sensor: Schritt 3, Bild 2 von 2
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: Schritt 4, Bild 1 von 2 Anki Vector Infrared Sensor Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: Schritt 6, Bild 1 von 2 Anki Vector Infrared Sensor Replacement: Schritt 6, Bild 2 von 2
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
Abschluss
Shay Takei
1.777 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G6, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 908
