Zum Hauptinhalt wechseln
Anne Pro 2 Case/Housing Replacement
Was du brauchst
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: Schritt 1, Bild 1 von 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: Schritt 1, Bild 2 von 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: Schritt 1, Bild 3 von 3
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: Schritt 2, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 2, Bild 2 von 2
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: Schritt 3, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 3, Bild 2 von 2
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: Schritt 4, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: Schritt 5, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 5, Bild 2 von 2
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: Schritt 6, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 6, Bild 2 von 2
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: Schritt 7, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 7, Bild 2 von 2
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: Schritt 8, Bild 1 von 2 Anne Pro 2 Case/Housing Replacement: Schritt 8, Bild 2 von 2
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mohamed
205 Reputation
1 Anleitung geschrieben
York University, Team S2-G3, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G3, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G3
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 131
Insgesamt: 10,056
