Einleitung
This guide will show you how to replace the Anne Pro 2 keyboard housing to a Zero-Degree case. This case is better for smaller hands, as well as more ergonomic. You can 3D print this case (link provided in Parts section).
Was du brauchst
Unplug the Anne Pro 2 Keyboard.
Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
Remove the PCB from the main case.
Gently lower the PCB into the Zero-Degree housing from the top side first.
Firmly press it in once you have lowered it.
Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
Firmly press them in, ensuring they are flush with the rest of the keys.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here- https://www.techtoreview.com/top-picks/a...
