Zum Hauptinhalt wechseln
Aorus 15P XD SSD Replacement
Was du brauchst
  1. Aorus 15P XD SSD Replacement, SSD: Schritt 1, Bild 1 von 2 Aorus 15P XD SSD Replacement, SSD: Schritt 1, Bild 2 von 2
    • First, make sure the power is off and disconnect the power.
    • Use a Torx security screwdriver to remove twelve 1.2 mm screws from the back case.
    • Use an opening tool to gently separate the front and back case. Work your way around the perimeter of the laptop and undo the clips holding it together.
    • Remove the back case.
  2. Aorus 15P XD SSD Replacement: Schritt 2, Bild 1 von 3 Aorus 15P XD SSD Replacement: Schritt 2, Bild 2 von 3 Aorus 15P XD SSD Replacement: Schritt 2, Bild 3 von 3
    • Use a JIS screwdriver to remove the single 8 mm screw securing the SSD in place.
    • Slide the SSD out of the socket connected to the motherboard.
    • Slide your new or upgraded SSD in the socket securely and replace the 8 mm screw.
  3. Aorus 15P XD SSD Replacement: Schritt 3, Bild 1 von 1
    • Set the back case on the laptop but don't replace the screws yet.
  4. Aorus 15P XD SSD Replacement: Schritt 4, Bild 1 von 3 Aorus 15P XD SSD Replacement: Schritt 4, Bild 2 von 3 Aorus 15P XD SSD Replacement: Schritt 4, Bild 3 von 3
    • Turn the device back on and open the advanced storage settings.
    • Choose the storage used on other drivers.
    • Next, check if the storage you installed is recognized in local disk storage.
  5. Aorus 15P XD SSD Replacement: Schritt 5, Bild 1 von 2 Aorus 15P XD SSD Replacement: Schritt 5, Bild 2 von 2
    • If the storage is detected, replace the screws.
    • If your storage is not detected, open the back case to make sure the SSD is plugged in tightly to the socket. If not, go back to Step 2.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Weitao Shi
142 Reputation
1 Anleitung geschrieben
York University, Team M-26, Allen Summer 2022 Mitglied von York University, Team M-26, Allen Summer 2022
YORK-ALLEN-SU22SMG26
1 Mitglied
3 Kommentare
Thanks, does the new SSD need thermal pad as well? And if so what thickness?
Martijn Spits - Antwort
Yes. what thickness is required? and which one is gen 3 and gen 4 slots?
Mark Jose -
I read that the one slot can be used for gen3 or sata, however I don't see where might the sata drive can be placed inside this laptop.
Mark Jose - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 92
Insgesamt: 3,825
