Zum Hauptinhalt wechseln
Aorus X7 v2 I/O Board Replacement
Was du brauchst
  1. Aorus X7 v2 I/O Board Replacement, I/O Board: Schritt 1, Bild 1 von 3 Aorus X7 v2 I/O Board Replacement, I/O Board: Schritt 1, Bild 2 von 3 Aorus X7 v2 I/O Board Replacement, I/O Board: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $5.49
    Kaufen
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Locate the speaker on the right-hand side of the device.
    • Remove the four red and black braided cables by gripping the black plastic piece on each cable and gently tugging to separate it from the white outlet.
  2. Aorus X7 v2 I/O Board Replacement: Schritt 2, Bild 1 von 3 Aorus X7 v2 I/O Board Replacement: Schritt 2, Bild 2 von 3 Aorus X7 v2 I/O Board Replacement: Schritt 2, Bild 3 von 3
    Phillips #0 Screwdriver
    $5.49
    Kaufen
    • Use the Phillips #0 Screwdriver to remove the two screws holding the speaker in place. Lift off the speaker panel.
    • Use the Phillips #0 Screwdriver to remove the three screws holding the board in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
  3. Aorus X7 v2 I/O Board Replacement: Schritt 3, Bild 1 von 3 Aorus X7 v2 I/O Board Replacement: Schritt 3, Bild 2 von 3 Aorus X7 v2 I/O Board Replacement: Schritt 3, Bild 3 von 3
    $5.49
    Kaufen
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the screw.
    • Place a finger under the board (see photo for location reference) and slowly lift up to remove the board.
Abschluss
Complete these steps in reverse order to install your new I/O Board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team 1-4, Pee Fall 2022 Mitglied von Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 345
