Zum Hauptinhalt wechseln
Aoson R103 Device Page Glass Screen Replacement
Was du brauchst
  1. Aoson R103 Device Page Glass Screen Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 1 von 3 Aoson R103 Device Page Glass Screen Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 2 von 3 Aoson R103 Device Page Glass Screen Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 3 von 3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Device Page Glass Screen Replacement: Schritt 2, Bild 1 von 2 Aoson R103 Device Page Glass Screen Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Device Page Glass Screen Replacement, Glass Screen: Schritt 3, Bild 1 von 2 Aoson R103 Device Page Glass Screen Replacement, Glass Screen: Schritt 3, Bild 2 von 2
    • Locate the four (0.4 mm) screws positioned near the cameras at the top of the device, and use a screwdriver to unscrew them. (Circles).
  4. Aoson R103 Device Page Glass Screen Replacement: Schritt 4, Bild 1 von 2 Aoson R103 Device Page Glass Screen Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • To disconnect the ribbon connectors, first, you need to flip up the tabs located above the ribbon gently. This will release the ribbon from the connector. Then, you can use tweezers to gently pull the ribbon out of the connector. Remember to be careful and avoid pulling too hard to prevent damage to the ribbon or connector.
  5. Aoson R103 Device Page Glass Screen Replacement: Schritt 5, Bild 1 von 3 Aoson R103 Device Page Glass Screen Replacement: Schritt 5, Bild 2 von 3 Aoson R103 Device Page Glass Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove the glass screen by unfastening all of the clasps located around the outer edge of the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Eric Puleo
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 49
Insgesamt: 388
