Zum Hauptinhalt wechseln
Apex TM772 Camera Replacement
Was du brauchst
  1. Apex TM772 Camera Replacement, Casing: Schritt 1, Bild 1 von 1
    • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
  2. Apex TM772 Camera Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Moving along the seam continue to pry the case apart.
    • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
  3. Apex TM772 Camera Replacement: Schritt 3, Bild 1 von 1
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
  4. Apex TM772 Camera Replacement, Front Camera: Schritt 4, Bild 1 von 1
    Kaufen
    • The front camera is located at the top right as looking inside the device.
    • With tweezers or your fingers remove the tape covering the camera’s pin connector.
  5. Apex TM772 Camera Replacement: Schritt 5, Bild 1 von 1
    • With tweezers, flip the black latch to open the pin connector and remove the cable.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 89
